Intel® Optane™ Memory
1396 Discussions
Recibo el error 0xA0050055 cuando intento activar la memoria Optane, esto luego de cambiar de un disco duro hdd (de fabrica) a un ssd (kingstone a400) Equipo acer nitro AN515-52
jvill26
DiegoV_Intel
Hi jvill26,
Thank you for posting in the Intel® communities.
I understand you are getting the error code 0xA0050055. This error code is related to some kind of compatibility issue between the system and the module.
I highly recommend you to contact your laptop manufacturer (Acer* in this case) to get better assistance on setting up the module, and also to check if the module is indeed supported with your current setup.
Configuring laptop systems is not the same as with Desktop computers. They usually include special features at BIOS and OS level that we are not aware of, so we always recommend to contact the manufacturer before doing any system changes, special if a hardware part like the HDD is going to be replaced.
If the module is compatible with your laptop model, then Acer* should help you to configure it with your new SSD.
I hope you find this information helpful.
Have a nice day.
PD.: The community support is only provided in English.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi jvill26,
Have a nice day.
Diego V.
