Intel® Optane™ Memory
1396 Discussions
Since installing the Optane memory my PC suddenly shuts don. When I reboot it says THe Operating System did not shut down cleanly Reading Cache Meta data
SWilk7
Has anyone else experienced this and found a fix?
LeonWaksman
Could be that your computer shutted down as result of temporary power interruption or overheat condition. This can happen. Any way after reading the Cache Meta data (which is normal after such event), you computer restarted again? So, if your computer is working now, no any fix is needed.
Leon
SWilk7
I think there is something that needs fixed as it shuts down every time it sits idle for a time.
LeonWaksman
  1. Please download Intel System Support Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
  2. Run the Intel SSU and the generated report saved in txt file, please attach to your post.
Leon
