Intel® Optane™ Memory
1390 Discussions
Was the Optane software pulled due to a bug we should know about?
BHarr8
Valued Contributor I
I was checking to see if there were any new updates today and I noticed that the current Optane software package is missing:
https://downloadcenter.intel.com/product/99745/Intel-Optane-Memory
I tried to link in from an alternate source here:
https://www.intel.com/content/www/us/en/support/articles/000024385/memory-and-storage.html
And that link is now a dead end.
Older versions are still available so I am wondering if there is a compelling reason to use one of the older versions until a new build is released.
JosafathB_Intel
Hello BHarr8,
Thank you for contacting Intel® Memory & Storage Support.
As we understand, you need assistance with the Intel® Optane™ Memory Software. If we infer correctly we will appreciate if you can review the following information:
•   You can download the “SetupOptaneMemory.exe” installer in the following link:
https://downloadcenter.intel.com/download/28966/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver
On this link, you can find the necessary and latest software to accelerate your system using the Intel® Optane™ memory modules
•   Which file to choose?
-SetupOptaneMemory.exe
Specifically designed and optimized to support system acceleration with Intel® Optane™ memory modules
-SetupRST.exe
Supports system acceleration with Intel® Optane™ memory in addition to advanced features such as management of RAID 0/1/5/10 volumes.
-f6flpy-x64.zip (64-bit Operating System) / f6flpy-x86.zip (32bit Operating System):
Standalone Intel® RST Drivers with Intel® Optane™ memory support
May be required during Operating System (OS) installation to detect PCIe* NVMe* drive, refer to system manufacturer documentation or Intel Customer Support
-Note
•   Only one of the Setup (SetupRST.exe or SetupOptaneMemory.exe) applications can be installed on a system at a time. Choose the application that makes the most sense for your intended usage and configuration.
•   The Intel® RST driver SetupRST.exe supports RAID 0, 1, 5 and 10. The driver should be installed after the operating system has been installed. F6 and RAID BIOS configurations need to be performed before the installation of this driver for proper operation. This driver supports NVMe devices.
If you need further assistance, please do not hesitate to contact us back.
Have a nice day.
Josh B.
Under Contract to Intel Corporation
JosafathB_Intel
Hello BHarr8,
-SetupRST.exe
-Note
Have a nice day.
Josh B.
JosafathB_Intel
Hello BHarr8,
Thank you for having contacted Intel® Memory & Storage Support.
This is just a friendly reminder that your case remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
A Contingent Worker at Intel
BHarr8
Not really a case, was just wondering if the download was pulled. Seems it was just moved to the RST page and a few orphaned links now point to nothing.
JosafathB_Intel
Hello BHarr8,
Thank you for your reply,
We appreciate your feedback regarding the Optane software links and our department in charge of the download center will be informed about the orphaned links that you mentioned.
We would like to know if you need further assistance or if we can close this case.
We will be looking forward to your reply.
Have a nice day.
Josh B.
JosafathB_Intel
Hello BHarr8,
Josh B.
