Intel® Optane™ Memory
1396 Discussions
intel optane functions normally when enabled but upon restarting the system from a shutdown, optane disables itself. how can i fix this
CMcMa
CMcMa
CMcMa
here is SSU logs while intel optane is freshly enabled.
JosafathB_Intel
Hello CMcMa, Thank you for contacting Intel® Memory & Storage Support. As we understand, you need assistance with your Intel® Optane™ Memory. If we infer correctly we will appreciate if you can provide us with the following information: • Your system configuration including manufacturer, model and part number of all your system components and a new copy of the SSU logs in the system that the Optane is connected. 1- Go to https://downloadcenter.intel.com/download/25293/ and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply. • A screenshot of the version of the software that you are using to manage your Optane. • We advise you to open a ticket in parallel with your motherboard OEM (original equipment manufacturer)to check the BIOS and Hardware configuration. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello CMcMa,
Thank you for having contacted Intel® Memory & Storage Support.
This is just a friendly reminder that your case remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
JosafathB_Intel
Hello CMcMa,
Thank you for having contacted Intel® Technical Support.
I was reviewing your community post and we would like to know if you need further assistance or if we can close this case.
Josh B.
A Contingent Worker at Intel
