Intel® Optane™ Memory
1391 Discussions
it seems that it is not so easy to install optane memory for casual users... even some IT specialist must waste a lot of time that optane can be used...
AKazl1
4 example i allready have ssd with win 10 64bit + 6tb hdd with data in it (that i want to accelerate with optane) and i was thinking that instaliation will be simple but... cant find ways... maybe its better to create program that FIX all things from start to END like change hdd status + create additional partitions and etc (what is needed for optane)  or i cant find videos with examples what must be DONE IN BIOS... u just writing but i would like to see how and what u changing in bios if win10 allready instled... and in same cases after bios settings changing the win10 not booting at all :)
DiegoV_Intel
Hi AKazl1,
Thank you for posting in the Intel® communities.
I understand you have had some issues trying to setup the Intel® Optane™ Memory.
Indeed, there is a configuration that must be done in BIOS and OS level to get the module working in the system, however this process and configuration highly depends on every motherboard and every particular BIOS, and the system manufacturer too. That’s the reason why an application that configures all the system settings automatically cannot be developed. This would depend instead on every manufacturer, if they decide to develop such application. Actually, some of them have done it so you can setup the module in an easier way, but as I mentioned, this depends on every manufacturer.
Having said this, I can try to help you configuring the module in your system. We will just need some information about your system.
Please download the Intel® System Support Utility (SSU) from the following site and run the full report. This report will include all details of your system. Please export the data in a text file and share it in your response: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Additionally, please take a screenshot of the Disk Management window. You can open Disk Management by pressing the Windows* key + x, and then selecting the Disk Management option from the menu that will appear.
Finally, please run the following commands in the Command Prompt to take another screenshot:
  1. Open the Command Prompt as Administrator.
  2. Run the command diskpart.
  3. Run the command list disk. Please take a screenshot of this output.
I will be waiting for your response.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
Santiago_A_Intel
Hello, AKazl1, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Santiago A. Intel® Customer Support Technician Under Contract to Intel Corporation
AKazl1
ohhh it takes a lot of time... instal 1 2 3 programs then send tests to you wait for response then again instal something / change somethings... and so on and on... i have optane 1 or 1,5 month and still still its not used.... its to complicated.... :/ 2019-03-05, an, 00:40 Intel Forums <supportreplies@intel.com> rašė:
Santiago_A_Intel
Hi AKazl1, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Please bear in mind our support is available to assist as soon as you send us your reply. Best regards, Santiago A. Intel® Customer Support Technician Under Contract to Intel Corporation
Santiago_A_Intel
Hi AKazl1,
Thank you for contacting Intel® SSD support group with your request for assistance with your Intel® Optane™ Memory.
We’ve read your comment and understand this is a new installation and we will proceed as such.
Since we don’t have sufficient details about your system, we are requiring with your cooperation to provide us with some information about it. To do this, Intel® has available, the Intel® System Support Utility for Windows*; you’ll be able to download it on the following link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
·        Please download the software.
·        When finished downloading it, open it and follow instructions
·        Please attach the SSU Log text file obtained on your next your reply.
Also, your motherboard manufacturer has probably created an Optane™ Memory instruction manual, in order to perform the basic setup to use your Optane™ memory in your system; therefore, we need to know further details on your system, we can look for this information, by reading the Logs after running the System Support Utilities (SSU’s) and recommend to follow their instructions.
For your benefit, Intel® has created several tools to help you out, please follow instructions on the Installation Guide for Intel® Optane™ Memory; it can be found on the following link: https://www.intel.com/content/www/us/en/support/articles/000023989/memory-and-storage/intel-optane-memory.html
In addition to this, Intel® offers convenient video resources to accomplish your Optane™ Installation, please follow this link: https://www.intel.com/content/www/us/en/support/articles/000023884/memory-and-storage/intel-optane-memory.html
To help you further with your request, It will be very helpful to receive from you, a screenshot of the “Disk Management” of windows, showing all your HDDs and partitions.
Please let us know if you might need additional support with your installation.
We will be looking forward to your reply.
Santiago A.
Santiago_A_Intel
Hi AKazl1,
Greetings from Intel® SSD Support.
This is a friendly reminder your case remains open, awaiting for your reply.
Please let us know if you might need further assistance.
Have a nice day.
Santiago A.
