Intel® Optane™ Memory
1387 Discussions
optane driver wont install because efi partition at end of drive
TTalb1
I just got the optane but the driver at install gives error 0x001004B. The error support page says to resize the efi partition which is located at the end of the drive but i can't get the efi partition do anything as its locked. No partition program will move it or resize it nor can a create another partition behind the efi to give the 5mb space needed to load the driver. How can I get this thing to work?
intel i7-7000k
rog maximus ix hero
16g ram
Hi cromlots,
Thank you for contacting our support community. We understand your concern regarding the Intel® Optane™ Memory.
Based on your information, It seems that you need to reinstall Windows(R) 10 because once the EFI partition is at the end of the drive it can't be moved.
We recommend you to leave 5MB at the end of the drive during the Windows* installation. Also, make sure to physically remove the Intel® Optane™ Memory before installing Windows*, otherwise it will create a system partition.
Make sure that you have the following BIOS settings before installing Windows*:
1- Boot into your BIOS
2- Press F7 to go to the advanced mode.
3- Go to Boot\CMS (Compatibility Support Module) and make sure is disabled.
4-Go to advanced\PCH Storage Configuration and check the following information:
A- SATA Mode Selection: Intel RST Premium with Intel(R) Optane(TM) System Acceleration(RAID).
After that, press f10 to save changes.
Once you have the settings applied to the system, you can reinstall Windows* with the method suggested above(5MB of unallocated space).
Please let us know the outcome of your situation.
Junior M.
TTalb1
ok thanks for the response unfortunately I upgraded from windows 7 to 10. I have no actual copy of windows 10. Unless theres another way seems I wasted my money. I don't suppose cloning the OS, change the bios and then putting windows back will work?
Hi cromlots,
Thanks for the reply.
We would like to inform you that the cloning process will not work because it will clone the SSD with the EFI partition at the end so you will get the same output.
Since you upgraded from Windows 7* to Windows(R) 10, you need to activate your Windows* via Digital entitlement(Digital License). This License is associated with the Microsoft* account you used during the Windows(R) 10 upgrade. However, we recommend you to contact https://www.intel.com/content/www/us/en/support/topics/oems.html Microsoft* in order to get assistance with the reinstall and activation process.
For further information please check the links below:
-https://support.microsoft.com/en-au/help/12440/windows-10-activation Activation in Windows 10 - Microsoft.com
-https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install/how-to-install-and-activate-windows-10-using-your/d713f9f9-e91f-4ffe-a3c0-7ef9639a0559 How to install and activate Windows 10 using your Windows 7 or Windows 8 product key - Microsoft.com
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
Junior M.
TTalb1
ok thanks. looks like i can download a hard copy of win 10. just a matter of losing my programs so i'll weigh the options
looks like i might be able to pull it off according to a site i found
https://lifehacker.com/5983652/how-to-do-a-clean-install-of-windows-without-losing-your-files-settings-and-tweaks storybreak stars');background-repeat:no-repeat;background-position:center}.editor .editor-inner div.legacy-raw-html,.pos…
Hi cromlots,
Junior M.
Hi cromlots,
We would like to know if you read our previous post. If you have any other questions, we'll be waiting for your response.
Junior M.
TTalb1
Yes I've read it but I couldn't get back in as I lost all my data because I had to start from scratch to get the optane to work. And then it wouldn't work but i found documentation online on how to reset it. Im happy with the product and tech support however these things should be made clear about installation . I read a bunch of reviews on it but none mention the criteria you need to install it. It's not just plug and play like one is led to believe. It's only cause I'm somewhat techsavvy that I got it going. 16 hrs later
Hi cromlots,
We are glad to hear that your situation has been resolved.
If you have further questions then feel free to contact us again.
Junior M.
