Intel® Optane™ Memory
1398 Discussions
there is no compatible disc for intel optane memory :c
MReye4
CPU: I5 7500
Motherboard: MSI b250 krait gaming
Storage : HDD (GPT)
Hi, I bought and intel optane memory 16 GB, but when installing the drivers happened that and I don't know what to do, MSI says that I just have to activate Optane Genie and all the configuration is ready for the use of intel optane but this problem happens. pls thanks for your help.
I attach information and SS
MReye4
some moderator can close this post, I solved the problem changing to Enabled the option "Windows 8.1/10 WHQL Support" and new option appears in Integrated Peripherals "M2_2 - RST Pcie Storage Remapping -> Enabled" then switch to the other port m2 my intel optane and the problem was solved (As in the screenshots that I attached). I leave this here if other MSI users have the same confusion / problem
MReye4
actualization:
I saw the drivers for my MotherBoard in the msi page and here there is driver of intel optane ver 15.9 (firstly I installed the latest version from Intel v16.5) and now don't show me the same problem, now tells me that no intel optane memory modules have been detected in the device.
MReye4
