Intel® Optane™ Persistent Memory
Examine Issues Related to Intel® Optane™ Persistent Memory
101 Discussions
Optane NVDIMM backwards compatibility
gourd
We are putting together a server for research and considering whether we should include Optane. I have a couple questions about Optane NVDIMM support that I wasn't able to answer elsewhere:
1) Do 5th-gen and later Xeon CPUs support Optane NVDIMMs?
2) Is support for newer Optane generations compatible with older ones? For instance, 4th-gen Xeons support 300 series Optane; does that mean that they also support 100 and 200 series?
Thanks for your assistance.
Ragulan_Intel
Hi Gourd,
Greetings!
Thank you for reaching out to Intel Community!
Please find the answers below for your queries. If there is any further clarification needed, please do let us know.
Please be informed Intel has dropped Optane Persistent Memory Support from 5th Gen Xeon processors onwards.
Intel Optane persistent memory is designed for use with the 2nd and 3rd Gen Intel Xeon Scallable Processors family and is enable by a sub-set of processors, primarily enabled by the Gold and Platinum tier models.
The Intel Optane PMem 200 series is enabled with 3rd Gen Intel Xeon Scalable Processors. The Intel Optane PMem 100 series is enabled with the 2nd Gen Intel Xeon Scalable Processors. PMem modules are not enabled in any other hardware combinations. Mixing PMem generations or product capacity SKUs within a system is not supported. The DDR4 and provisioned PMem Module`s memory configuration shall be uniformly configured and provisioned across all sockets.
You can refer to this link for further clarification: https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/data-center-persistent-mem/Intel_Optane_Persistent_Memory_Start_Up_Guide.pdf
Just an additional information, the Effective January 31st, 2023, Intel has cancelled the Intel® Optane™ Persistent Memory 300 Series (previously code-named Crow Pass) and not develop future Intel Optane products.
Additional links that might be useful for your research:
Thank You & Best Regards,
Ragulan_Intel
Ragulan_Intel
Hi Gourd,
Greetings!
This is a gentle follow up to this request. Please do let us know if you have any concerns and we will assist you accordingly.
If everything is good, we would like to obtain your approval to archive this request.
Ragulan_Intel
Ragulan_Intel
Hi Gourd,
Greetings!
We are notifying you that your request will be archived as there are no pending actions from Intel Customer Support.
In the coming days, you may be invited to participate in a survey. Your feedback is highly valued, and we are eager to hear about your experience with our support.
Ragulan_Intel
