Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
5V max limit by ATX Spec for SSD's
JKR82
I am currently having a discussion about how many volts a 2.5'' SSD must be able to withstand. Regarding the Intel "developer_specs_ATX12V_1_3dg" chapter 3.2.1 the allowed max voltage for +5VDC is max +5.25V. However in chapter 3.4.1 Over-voltage Protection it says, "The supply shall provide latchmode over-voltage protection as defined in Table 14", and that is max 7.0V for the +5VDC rail.
How does Intel see this, do 2.5'' SSD's have to withstand 7.0V DC without interference to be used on ATX board?
Or are there 2.5'' Intel SSD's that are specified up to 7.0V, so that they can operate without hesitation on ATX power supplies?
ATX Spec attached
BrusC_Intel
Hello, JKR82.
Thank you for posting on the Intel community Support Forums.
I received your thread regarding this particular inquiry, and I will be reviewing this with you.
Can you provide us the exact model of the Intel drive(s) that you are using?
I will follow up on August 11th just in case you need additional time.
Bruce C.
BrusC_Intel
Hello, JKR82.
This post is to follow up on your thread to check if you can confirm the exact model (or models) of Intel SSD you are using.
I will follow up again on August 15th in case additional time is required.
Bruce C.
BrusC_Intel
Hello, JKR82.
This post is to inform you about the closure of this community thread.
I previously wanted to get more information regarding the drive (or drives) being used to check if there were any recommendations we could share, but there was no response from your part after trying to follow up.
The thread will be closed right now, and it will no longer be monitored by Intel support, but if you require any type of assistance from Intel in the future, just open a new thread, or contact us using any of the available support methods:
- https://www.intel.com/content/www/us/en/support/contact-intel.html
Bruce C.
