Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
483 Discussions
750GB P4800X OPTANE HHHL Low Performance
farero
​Hello,
I just added a 750GB P4800X DC OPTANE to a Dell R720 where I have also a P3700.
The performance that I get at host level es lower than expected:
At VM level, (Hyper-V) the performance is a lot worst:
I suppose something is wrong with the config but I cannot find what....
All suggestions are appreciated
Esteban_C_Intel1
Hello farero,
Thank you for contacting Intel Communities.
I checked the performance stats for Intel® Optane™ SSD DC P4800X Series 750GB, 1/2 Height PCIe x4, 3D XPoint™ and the results you got look pretty good.
The Sequential Read (up to) is 2500 MB/s, you got 2670.4 MB/s
The Sequential Write (up to) is 2200 MB/s, you got 2397.6 MB/s
Information taken from: https://ark.intel.com/content/www/us/en/ark/products/97164/intel-optane-ssd-dc-p4800x-series-750gb-1-2-height-pcie-x4-3d-xpoint.html
Also, all results are based on a "host" machine, no VM involved, in order to get performance recommendations on VMs it would be better to contact the VM software provider you are using.
Finally, for further recommendations or information about the best configuration for performance, you can refer to the performance evaluation guide for the unit you have: https://www.intel.com/content/www/us/en/support/articles/000032738/memory-and-storage/data-center-ssds.html
farero
Thanks Esteban for the reply.
The Operating system is Windows 2016; I will try to get ideas from the Linux performance guide that you have linked.
About the host performance I was expecting better results in the areas that the Optane technology is better than a traditional SSD. The sequential values are correct, the all 4K values are low, they are like a P3700 and they should be superior.
I was expecting at least 2000 MB/s (Q8T8), 500 MB/s (Q32T1), 200 MB/s (Q1T1).
Esteban_C_Intel1
Thank you for the answer, farero.
The results or data that we have tested seems fine compared to the results that you got, as we mentioned before, the sequential reads and writes are good so we are fine on that section.
Then on terms of 4K, the results available done with our benchmarks are random read and writes with 4K which can be seen on the evaluation guide I provided before (results section). Maybe you can review those results with the benchmarks provided in the same document (evaluation guide) and let me know if you see any good or bad scores related to the ones we got. Those results are provided in IOPS, therefore the benchmarks to be used by you would need to be in those.
Also, notice the results can change from one system to the other, that is something you can consider while doing the tests.
At this point everything looks fine, but if you want, you can provide the SMART details from your drive so I can review the drive's health. You can use the Intel® SSD Data Center Tool to extract them, there is a guide on the download page on how to use the tool.
Intel® SSD Data Center Tool download link: https://downloadcenter.intel.com/download/28999/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=87278
farero
​Hello,
I have send by private message the SMART report. It seems that everything is working propely, but Windows or the systems lowers the performance.
I have done more tests of the P4800X (RIGHT) in MB/s and also in IOPS and compared to P3700 (left):
Esteban_C_Intel1
Thank you for the data provided, I reviewed the scores and now I can actually see what you meant on previous posts regarding performance scores.
Please attach the Intel(R) SSU report to your answer so I can get this reviewed.
This is the link to download the tool mentioned:
Intel® System Support Utility for Windows*
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
farero
​I have send it by private message.
Thanks !!!
Esteban_C_Intel1
Terrific, I will get back to you as soon as possible.
Esteban C
A Contingent Worker at Intel
Esteban_C_Intel1
farero,
After getting your case reviewed the recommendation to be provided is to use the IOmeter from the link and follow the setup guide for performance. This is not exactly for the same SSD but you can use it since it indicates it can work with any other SSD.
https://www.intel.com/content/dam/support/us/en/documents/ssdc/hpssd/ssd-750/sb/intel_ssd_750_series_evaluation_guide_332075002us.pdf
Please let me know how it goes.
Esteban C
farero
​It has take me some time to do all that tests. Here are the results:
128K Sequential READ: 2670 MBPS (Datasheet: 2500MB/S)
128K Sequential Write: 2404 MBPS (Datasheet: 2200MB/S)
4KB Random Read: 304000 IOPS (Datasheet: 550000 IOPS)
 4KB Random Write: 287358 IOPS (Datasheet: 550000 IOPS)
Esteban_C_Intel1
.Thank you for the results, farero
Let me work on those results and your case to then get back to you.
Esteban C
Santiago_A_Intel
Hello farero,
I got your case reviewed and also performed tests on my end with IOMeter, I am currently working on them and I am sending this update to you because it is required to get some data from your end for further review.
Turns out the SMART logs provided were for a different drive, so it is required to ask for the proper logs again, please check the data below.
How to get the correct index number from the drive
Do the command: isdct.exe show -intelssd, it will look like the one attached, use the orange squares as a reference, you must use the correct drive index.
Once you have the correct index, use this command to extract the SMART logs: isdct.exe show –nvmelog smarthealthinfo -intelssd x (use the right index)
Finally, I was requested to ask for the .CSV files you got from IOMeter, you can attach them (read and write) to your answer together with the SMART logs.
Have a nice day,
Santiago A.
farero
​Hello Santiago,
I will prepare de CSV.
Here are the correct smart details:
C:\Users\Administrator>isdct.exe show -nvmelog smarthealthinfo -intelssd 0
- NVMeLog SMART and Health Information PH****************GN -
Data Units Written : 0xBB8240
Available Spare Normalized percentage of the remaining spare capacity available : 100
Available Spare Threshold Percentage : 0
Controller Busy Time : 0x69
Critical Warnings : 0
Available Spare Space has fallen below the threshold : False
Host Write Commands : 0x0D950635
Data Units Read : 0x8E73B3
Host Read Commands : 0x20AE6976
Media Errors : 0x0
Temperature - Celsius : 44
Number of Error Info Log Entries : 0x0
Percentage Used : 0
Power Cycles : 0x0C
Power On Hours : 0x017A
Media is in a read-only mode : False
Device reliability has degraded : False
Temperature has exceeded a critical threshold : False
Unsafe Shutdowns : 0x01
Volatile memory backup device has failed : False
Santiago_A_Intel
Hi farero;
Greetings from Intel® SSD communities.
Thank you for the information provided, we will be awaiting for the CSV file.
Please let us know if there’s anything else we can help you with.
We will be available to help you in any way we can.
Have a nice day
Santiago A.
farero
Hello Santiago.
Thanks for your reply. I have send you the CSV by private message.
Regards.
Esteban_C_Intel1
Thank you, farero.
Let me get them reviewed and get back to you.
Esteban C
Esteban_C_Intel1
farero,
This is to let you know we are still running tests on our end in order to further investigate on this matter.
I will keep you updated.
Esteban C
farero
Thanks !
Esteban_C_Intel1
farero,
I just sent a private message to you.
Esteban C
Esteban_C_Intel1
Sent information for NDA
Terrific, farero
In order to start the process, please provide the following information:
Company Name
Country
Main Contact (Name of the person who is asking for confidential information)
Contact Position or Job Title
Main Contact Phone Number
Main Contact Email
Physical Address
Esteban C
farero
