Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
Hi, Optane e RTS Drivers
FDRPg
Hi, just out of couriosity can some of these drivers improve performance on a Kingstone 225 SSD ?
https://downloadcenter.intel.com/product/99745/Intel-Optane-Memory
Windows 10 Pro 64-bit
Intel Core i5 7400 @ 3.00GHz
Kaby Lake 14nm Technology
should I just install the RTS drivers right ?
JosafathB_Intel
Hello FDRPg, Thank you for contacting Intel® Memory & Storage Support. As we understand you need assistance with the Intel® Optane™ Memory User Interface and Driver for System Acceleration, if we inferred correctly, we will appreciate if you can provide us with the following information: • As we understand you are interested in using an Optane memory to accelerate your Kingstone*SSD and we will like to know which Intel® Optane™ Memory Series do you have or which one are you interested in setting up in your system, the options available for this hardware module are the following: https://ark.intel.com/#@Optane • The SSU logs. 1- Go to https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply. • A screenshot of the “Disk Management” of windows showing all your HDDs and partitions (this to have a better view on how your SSD is detected by the OS) To answer your question: Just by installing the RST drivers or the Intel® Optane™ Memory User Interface and Driver for System Acceleration is not going to increase the performance of your SSD and you need to set up the Optane hardware and to have a compatible system. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello FDRPg, Thank you for contacting Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello FDRPg, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
