Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
509 Discussions
intel CAS could not start cache with Optane SSD
qq392784506
i buy a Optane 32G SSD, and use intel CAS to accelerate my PC. but it doesn't work,
BrusC_Intel
Hello, qq392784506.
Thank you for posting on the Intel Community Support forums.
I received your ticket regarding the Intel CAS setup, and I will be reviewing this with you.
The article "Which SSDs Are Supported by the Intel® CAS for Windows?" describes that any SATA, SAS, PCIe* drives larger than 5 GB and smaller than 16 TB can be used, but Intel Optane Memory devices are not Intel Optane Solid State Drives; Optane Memory units are meant to be used alongside the Intel Rapid Storage Technology driver to accelerate SATA drives (HDD or SSD), not Intel CAS:
- https://www.intel.com/content/www/us/en/support/articles/000058249/memory-and-storage/datacenter-storage-solutions.html
- https://www.intel.com/content/www/us/en/support/articles/000036880/memory-and-storage/intel-optane-memory.html
If I can help you with anything else, please let me know, and I will follow up on April 27th just in case.
Bruce C.
AlHill
What is your SATA mode in the bios?
qq392784506
I have a NVME SSD and SATA SSD. There are AHCI and Raid mode in the bios, but both of them have the same error.
qq392784506
AlHill
It seems to me that your motherboard bios does not support Optane.  Verify with the motherboard/system manufacturer that their BIOS supports optane.
qq392784506
According to the data, Optane does require a special motherboard if it uses intel RST technology to bind an HDD. However, intel CAS does not have requirements for the mainboard
AlHill
I may be wrong, but if the motherboard bios does not support optane, then it does not support optane.
Personally, I would not be using optane anyway.  You are only asking for problems.  This is why Intel abandoned Optane.
qq392784506
qq392784506_0-1682413917137.pngOptane can be seen in system and disk management and works like a normal SSD, but Intel CAS software cannot work. I purchased Optane just as a cheap transitional solution.
BrusC_Intel
Hello, qq392784506.
Bruce C.
qq392784506
Model: Intel® Optane™ Memory Series (32GB, M.2 80mm PCIe 3.0, 20nm, 3D XPoint™) Retail Box 10 Pack.
But there are many Chinese articles and videos that prove Optane Memory Series can be used with INTEL CAS.
Due to my limited ability, I did not find relevant English articles, please forgive me.
https://zhuanlan.zhihu.com/p/35882559
https://www.bilibili.com/read/cv6064023
AlHill
I will say it one more time - you are only asking for trouble by trying to use Optane.  Even on a motherboard that supports Optane, you will have problems.  Thinking that there is a chinese hack to do it will only make it worse.
And, regarding those Chinese articles, there is a thing called a translator....   Just saying.
BrusC_Intel
Hello, qq392784506.
Thank you for the additional information.
I see in those articles they were able to use it, but that particular use scenario is outside of our scope of support, I would recommend checking with the writer of the article or checking if there is is a comments (or support) section in those sites in case other users can help.
I will proceed to close this thread on April 28th if there are no other questions.
Bruce C.
BrusC_Intel
Hello, qq392784506.
This message is to inform you about the closure of this support thread.
We previously shared that  Intel Optane Memory devices are not Intel Optane Solid State Drives, and Optane Memory units are meant to be used alongside the Intel Rapid Storage Technology driver to accelerate SATA drives (HDD or SSD), not Intel CAS.
The thread will be closed right now and it will no longer be monitored by Intel support. If you require any type of assistance from Intel in the future, please open a new thread, or contact us using any of the available support methods:
- https://www.intel.com/content/www/us/en/support/contact-intel.html
Bruce C.
