Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
Deep Neural Network Library (DNNL), Installing Tensorflow (Binary)
Gert_Lindner
Target Mac: 19.0.0 Darwin Kernel Version 19.0.0: Thu Oct 17 16:17:15 PDT 2019; root:xnu-6153.41.3~29/RELEASE_X86_64 x86_64
1) I Installed the  latest Intel® Optimization for TensorFlow* from Anaconda* Cloud successfully "conda install tensorflow"
https://software.intel.com/en-us/articles/intel-optimization-for-tensorflow-installation-guide#Anaconda_main_linux
2) but the proposed sanity check
python -c "import tensorflow; print(tensorflow.pywrap_tensorflow.IsMklEnabled())"
failed with
File "<string>", line 1, in <module>
AttributeError: module 'tensorflow' has no attribute 'pywrap_tensorflow'
Gert_Lindner
Attached the whole installation procedure
ChithraJ_Intel
    Could you please check the tensorflow version installed by using the command
    python -c "import tensorflow; print(tensorflow.__version__)"
    If it is tensorflow 2.0.0(latest version), please try to install stable tensorflow version 1.14.0 by uninstalling the current version.
    conda uninstall tensorflow
    Please follow the below commands to install intel-optimized-tensoflow from anaconda channel
    conda create -n tf-conda python=3.6
    conda install tensorflow==1.14.0 -c anaconda
    If you still faces any issue, please feel free to get back to us.
Gert_Lindner
Thank you for guided steps. I received the results described in the attachement.
ChithraJ_Intel
Hey Gert,
Could you please confirm whether you are facing the same issue with tensorflow version 1.14.0
[ Run this command to check it: python -c "import tensorflow; print(tensorflow.pywrap_tensorflow.IsMklEnabled())" ]
Actually, this error is due to the tensorflow's version change to 2.0 has changed the tensorflow API structure significantly.
If you are planning to use tensorflow 2.0.0 in future, to check if MKL-DNN is enabled ( in tensorflow 2.0.0 ) , please use the below command(instead of the sanity check command in your answer)
python -c "from tensorflow.python import pywrap_tensorflow; print(pywrap_tensorflow.IsMklEnabled())"
you may not face this issue in earlier versions of tensorflow upto tensorflow 1.14.0
Gert_Lindner
Hi Chitra,
Yes I got ''True'
at the end of a long tail of "FutureWarning"
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:516: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint8 = np.dtype([("qint8", np.int8, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:517: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:518: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint16 = np.dtype([("qint16", np.int16, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:519: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:520: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint32 = np.dtype([("qint32", np.int32, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorflow/python/framework/dtypes.py:525: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  np_resource = np.dtype([("resource", np.ubyte, 1)])
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:541: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:542: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:543: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:544: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:545: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
/Users/lindne03/miniconda3/lib/python3.7/site-packages/tensorboard/compat/tensorflow_stub/dtypes.py:550: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
True
ChithraJ_Intel
Thanks for the confirmation. We are closing this case. Please feel free to raise a new thread for further issues.
