Intel® Optimized AI Frameworks
Receive community support for questions related to PyTorch* and TensorFlow* frameworks.
89 Discussions
Didn't get certificate for AI From the Data Center to the Edge
hanimansur
I completed the quiz for this course "AI From the Data Center to the Edge – An Optimized Path Using Intel® Architecture" but I didn't get the certificate to my email.
The quiz, according to the learning book, is on this link https://intel.az1.qualtrics.com/jfe/form/SV_9EIVi2JXNF1ViiV
Neither the certificate is showing up on Credly nor in my email, can anyone help with this?
Youssef_Ashraf11
I also haven’t received the certificate. Is there any update?
Ying_H_Intel
Hi @hanimansur @Youssef_Ashraf11
thank you a lot for raising the questions here.  will esclate the related team to handle this.
Just quick check , Are you learning the course in Course: AI From the Data Center to the Edge - An Optimized Path Using Intel® Architecture, which seems 3 years release. So want to make sure other URL if there is
thank you!
hanimansur
Hi @Ying_H_Intel ,
I received the badge for the course, either on Credly and in my email, thank you so much for your support.
hanimansur
Hi @Ying_H_Intel
Thank you for escalating the problem.
The learning course is in this link: https://www.intel.com/content/www/us/en/developer/topic-technology/artificial-intelligence/training/datacenter-to-edge.html
Also I believe it's the same one on Credly on this link: https://www.credly.com/org/intel/badge/ai-from-the-data-center-to-the-edge-an-optimized-path-using-intel-architecture
In this learning course link, there's a downloadable course content, and at the last pages of the PDF file inside this content there's a link for a quiz test, which is this link: https://intel.az1.qualtrics.com/jfe/form/SV_9EIVi2JXNF1ViiV.
After completing and passing the quiz and providing email the certificate neither shows up on Credly or on my email.
If you want any further info to help resolving this issue, please let me know. Also I will highly appreciate if you confirmed back with this issue is resolved to retake the quiz.
Thank you
Youssef_Ashraf11
Thank you, I downloaded the course from this link https://www.intel.com/content/www/us/en/developer/topic-technology/artificial-intelligence/training/datacenter-to-edge.html and passed the test more than once but it did not arrive. Now I received a badge but I did not receive the certificate.
hanimansur
I believe there's no certificate for this course, it's just a badge. There's no certificate grant is outlined anywhere either in the course page and on the Credly page.
Youssef_Ashraf11
Maybe but I found a certificate online for this course. If I had known that I would end up with this badge, I would not have taken this course anyway. Thank you.
Ying_H_Intel
Thank you a lot for the detail feedback!
To All:
I got clarification from the related team.
Please note
This course was meant to be removed from the system as it no longer has an owner.   The developer team will remove the content from the system.
Thanks for your patience and  welcome to try other AI courses in Intel® Github
