17258 Discussions
2 memory instances with different usages.
I have a MegaWizard created memory component in Quartus II 9.1 -
24 bit x 4k Word x 3 port
I have two different instances of this component, which should both be embedded in identical circuitry.
One instance has 3 x the resource usage of the other : 196608 vs. 65536
I could understand this if one instance usage was different to the other and was being optimised away, but this should be a symmetric design.
Any ideas ?
cheers,
Beau
;|mem_24b_4k_3p:inst15| ; 0 (0) ; 0 ; 65536 ; 0
; |alt3pram:alt3pram_component| ; 0 (0) ; 0 ; 65536 ; 0
; |altdpram:altdpram_component1| ; 0 (0) ; 0 ; 32768 ; 0
; |altsyncram:ram_block| ; 0 (0) ; 0 ; 32768 ; 0
; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 32768 ; 0
; |altdpram:altdpram_component2| ; 0 (0) ; 0 ; 32768 ; 0
;|mem_24b_4k_3p:inst6| ; 0 (0) ; 0 ; 196608 ; 0
; |alt3pram:alt3pram_component| ; 0 (0) ; 0 ; 196608 ; 0
; |altdpram:altdpram_component1| ; 0 (0) ; 0 ; 98304 ; 0
; |altsyncram:ram_block| ; 0 (0) ; 0 ; 98304 ; 0
; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 98304 ; 0
; |altdpram:altdpram_component2| ; 0 (0) ; 0 ; 98304 ; 0
--- Quote Start ---
Any ideas ?
cheers,
Beau
--- Quote End ---
without knowing the design details it is difficult to say, but I would look to the modules in front and behind the memory. I would expect that the synthesis tool could optimize the
two memories different.
Kind regards
GPK
