I have a MegaWizard created memory component in Quartus II 9.1 - 24 bit x 4k Word x 3 port I have two different instances of this component, which should both be embedded in identical circuitry. One instance has 3 x the resource usage of the other : 196608 vs. 65536 I could understand this if one instance usage was different to the other and was being optimised away, but this should be a symmetric design. Any ideas ? cheers, Beau ;|mem_24b_4k_3p:inst15| ; 0 (0) ; 0 ; 65536 ; 0 ; |alt3pram:alt3pram_component| ; 0 (0) ; 0 ; 65536 ; 0 ; |altdpram:altdpram_component1| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 32768 ; 0 ; |altdpram:altdpram_component2| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 32768 ; 0 ;|mem_24b_4k_3p:inst6| ; 0 (0) ; 0 ; 196608 ; 0 ; |alt3pram:alt3pram_component| ; 0 (0) ; 0 ; 196608 ; 0 ; |altdpram:altdpram_component1| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 98304 ; 0 ; |altdpram:altdpram_component2| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 98304 ; 0Link Copied
--- Quote Start --- Hi, I have a MegaWizard created memory component in Quartus II 9.1 - 24 bit x 4k Word x 3 port I have two different instances of this component, which should both be embedded in identical circuitry. One instance has 3 x the resource usage of the other : 196608 vs. 65536 I could understand this if one instance usage was different to the other and was being optimised away, but this should be a symmetric design. Any ideas ? cheers, Beau ;|mem_24b_4k_3p:inst15| ; 0 (0) ; 0 ; 65536 ; 0 ; |alt3pram:alt3pram_component| ; 0 (0) ; 0 ; 65536 ; 0 ; |altdpram:altdpram_component1| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 32768 ; 0 ; |altdpram:altdpram_component2| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 32768 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 32768 ; 0 ;|mem_24b_4k_3p:inst6| ; 0 (0) ; 0 ; 196608 ; 0 ; |alt3pram:alt3pram_component| ; 0 (0) ; 0 ; 196608 ; 0 ; |altdpram:altdpram_component1| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 98304 ; 0 ; |altdpram:altdpram_component2| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram:ram_block| ; 0 (0) ; 0 ; 98304 ; 0 ; |altsyncram_g4q1:auto_generated| ; 0 (0) ; 0 ; 98304 ; 0 --- Quote End --- Hi, without knowing the design details it is difficult to say, but I would look to the modules in front and behind the memory. I would expect that the synthesis tool could optimize the two memories different. Kind regards GPK
