17244 Discussions
2D Array in Verilog is Synthesizable (Using Quartus)?
HBhat2
New Contributor II
localparam [15:0] SYMBOL_OS [0:7] = {  16'h0A, 16'hA0,16'h1A, 16'hA2, 16'h1F, 16'hA5, 16'h58, 16'h93  };
I have above 2 dimensional array in one of my verilog module. Whether above statement is synthesizable with Quartus?
FYI, when I simulate (using Modelsim), I need to write the above Symbol declaration as
localparam [15:0] SYMBOL_OS [0:7] = ' {  16'h0A, 16'hA0,16'h1A, 16'hA2, 16'h1F, 16'hA5, 16'h58, 16'h93   };
With Regards,
HPB
KhaiChein_Y_Intel
You can use 2D array in the Intel Quartus Prime software.
Synthesis tools typically consider all signals and variables that have a multi-dimensional array type and then create a RAM block, if applicable. This is based on the way the signals or variables are assigned orreferenced in the HDL source description.
