17249 Discussions
A bug in quartus_pgm ?
Hi,everyone.
I follow the example20-1 in the altera's file"qts_qii53022.pdf".The example20-1 in page 31.The command and result are as follows:
quartus_pgm -c usb-blaster -m jtag -o bpv;test.sof
Info: *******************************************************************
Info: Running Quartus II Programmer
Info: Version 7.2 Build 151 09/26/2007 SJ Full Version
Info: Copyright (C) 1991-2007 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Fri Nov 13 19:19:22 2009
Info: Command: quartus_pgm -c usb-blaster -m jtag -o bpv;test.sof
Info: Using programming cable "USB-Blaster [USB-0]"
Info: Started Programmer operation at Fri Nov 13 19:19:28 2009
Info: Ended Programmer operation at Fri Nov 13 19:19:28 2009
Info: Quartus II Programmer was successful. 0 errors, 0 warnings
Info: Allocated 162 megabytes of memory during processing
Info: Processing ended: Fri Nov 13 19:19:28 2009
Info: Elapsed time: 00:00:06
But the FPGA was not programmed.I don't know why?
best wishes
han
do you mean by not programmed that the fpga lost it's configuration after power off ? thats normal as the altera FPGAs are volatile types.
the quartus programmer is used to "test" your image and let it run on the target.
Thank you for your reply,MSchmitt.But I didn't power off.I think the sof file wasn't downloaded,because the blaster just flash three times,it didn't light for some time.
--- Quote Start ---
--- Quote End ---
Not actually. You modified a command for CPLD device using a *.pof file. Unfortunately, *.sof file download has neither a blankcheck nor a
verify option. The invalid options may be reason enough for the Quartus Programmer to ignore the complete command. I didn't check.
Do you have particular reasons not to use the interactive programmer tool? It would be at least helpful to find out about valid programming options.
Hi FvM.
Thank you for you advise.I have used the interactive programmer tool and .sof file was download successfully.
Now I can download successfully by use the command "quartus_pgm -c usb-blaster -m jtag -o p;test.sof@2".The blaster cann't choose the right device with the verify option comand,So I must help the blaster to choose the devie_2 by the command "@2".
thanks all for your pure-hearted replay.
hi,
is it possible to program the device through the script.
I want to use quartus_pgm -c USB-Blaster -m JTAG -o P;mux2_1.sof
in my script show below.Plz correct me where I am wrong.
email::ksharma30.AT. gmail
load_package flow
project_new test3 -overwrite
# Assign family, device, and top-level file
set_global_assignment -name FAMILY CycloneII
set_global_assignment -name DEVICE EP2C70F896C6
set_global_assignment -name VERILOG_FILE mux2_1.v
set_global_assignment -name TOP_LEVEL_ENTITY mux2_1
# Assign pins
set_location_assignment -to clk Pin_AD15
set_location_assignment -to reset Pin_T29
# compile the project
execute_flow -compile# execute_module -tool map# execute_module -tool fit# execute_module -tool tan# execute_module -tool asm# execute_module -tool eda
# Other assignments could follow
project_close
