Hi,everyone.
I follow the example20-1 in the altera's file"qts_qii53022.pdf".The example20-1 in page 31.The command and result are as follows: quartus_pgm -c usb-blaster -m jtag -o bpv;test.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Version 7.2 Build 151 09/26/2007 SJ Full Version Info: Copyright (C) 1991-2007 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Fri Nov 13 19:19:22 2009 Info: Command: quartus_pgm -c usb-blaster -m jtag -o bpv;test.sof Info: Using programming cable "USB-Blaster [USB-0]" Info: Started Programmer operation at Fri Nov 13 19:19:28 2009 Info: Ended Programmer operation at Fri Nov 13 19:19:28 2009 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Allocated 162 megabytes of memory during processing Info: Processing ended: Fri Nov 13 19:19:28 2009 Info: Elapsed time: 00:00:06 But the FPGA was not programmed.I don't know why? best wishes hanLink Copied
do you mean by not programmed that the fpga lost it's configuration after power off ? thats normal as the altera FPGAs are volatile types.
the quartus programmer is used to "test" your image and let it run on the target.- Mark as New
Thank you for your reply,MSchmitt.But I didn't power off.I think the sof file wasn't downloaded,because the blaster just flash three times,it didn't light for some time.
--- Quote Start --- I follow the example20-1 in the altera's file"qts_qii53022.pdf". --- Quote End --- Not actually. You modified a command for CPLD device using a *.pof file. Unfortunately, *.sof file download has neither a blankcheck nor a verify option. The invalid options may be reason enough for the Quartus Programmer to ignore the complete command. I didn't check. Do you have particular reasons not to use the interactive programmer tool? It would be at least helpful to find out about valid programming options.
Hi FvM.
Thank you for you advise.I have used the interactive programmer tool and .sof file was download successfully. Now I can download successfully by use the command "quartus_pgm -c usb-blaster -m jtag -o p;test.sof@2".The blaster cann't choose the right device with the verify option comand,So I must help the blaster to choose the devie_2 by the command "@2". thanks all for your pure-hearted replay.- Mark as New
hi,
is it possible to program the device through the script. I want to use quartus_pgm -c USB-Blaster -m JTAG -o P;mux2_1.sof in my script show below.Plz correct me where I am wrong. email::ksharma30.AT. gmail ///////////////////////////////////////// load_package flow project_new test3 -overwrite # Assign family, device, and top-level file set_global_assignment -name FAMILY CycloneII set_global_assignment -name DEVICE EP2C70F896C6 set_global_assignment -name VERILOG_FILE mux2_1.v set_global_assignment -name TOP_LEVEL_ENTITY mux2_1 # Assign pins set_location_assignment -to clk Pin_AD15 set_location_assignment -to reset Pin_T29 # compile the project execute_flow -compile# execute_module -tool map# execute_module -tool fit# execute_module -tool tan# execute_module -tool asm# execute_module -tool eda # Other assignments could follow quartus_pgm -c USB-Blaster -m JTAG -o P;mux2_1.sof project_close ////////////////////////////////////////// Thanks
