Anybody understand this error code???
Internal Error: Sub-system: PGMWQ, File: /quartus/pgm/pgmwq/pgmwq_device_dlg.cpp, Line: 343 Invalid Initial family Stack Trace: 0x5aaea: pgmwq_select_hardware_and_close + 0x8baa (pgm_pgmwq) 0x635d0: pgmwq_select_hardware_and_close + 0x11690 (pgm_pgmwq) 0x276c35: QWindowsXPStyle::styleHint + 0x2d5 (QtGui4) End-trace I was trying to change the frequency properties of an EEPROM device, but this message came up and the program stopped.Link Copied
usually there isn't enough information in the trace to gather any useful information. though yours does say Invalid Initial family
can you provide steps to reproduce this and/or file an SR?- Mark as New
--- Quote Start --- usually there isn't enough information in the trace to gather any useful information. though yours does say Invalid Initial family can you provide steps to reproduce this and/or file an SR? --- Quote End --- well basically i plug in the usb blaster, atuo detect the device, and then double click on the device properties and thats when it crashes.
hm, i just tried the same on Windows and 10.0 and didn't get a crash. i am targeting an AIIGX, which device were you trying to use?
--- Quote Start --- hm, i just tried the same on Windows and 10.0 and didn't get a crash. i am targeting an AIIGX, which device were you trying to use? --- Quote End --- I wish i could answer that confidently!! I Dont know a lot about the device itself only that its An EEPROM(EP20K1000EFC672).
ok this is as i was expecting. APEX 20K is a bit older of a family. i'm not sure which versions of the programmer supported it. try taking a look at the device support in older release notes to find APEX 20K:
http://www.altera.com/literature/lit-rn-q2_archive.jsp- Mark as New
it still shouldn't have an Internal Error, so file an SR if you can
Topic Options
