17249 Discussions
ADC Toolkit - no associated hardware
James44
Hi @ShengN_Intel
So I turned off the debug option when building a .bcf file to use less logic elements because I'm using the 10M04SAE144 chip. Does this mean I won't be able to run the ADC Toolkit in the Platform Designer?
It's saying no associated hardware. Here's a screenshot:
I was following this tutorial
https://youtu.be/0oO1RFa-4Xk?feature=shared
Thank you 
AqidAyman_Intel
Hi James,
Is there any more support needed after the clarification by @ShengN_Intel?
ShengN_Intel
Yes, disable Debug Path then not able to run the ADC Toolkit. Debug Path will implement high number of LEs. If wants to use that may be can use a larger board like 10M08 mentioned in video.
Sheng
AqidAyman_Intel
Hi James,
James44
Thank you. No more support needed on this topic.
AqidAyman_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you.
