16624 Discussions
ALT_MULT_COMPLEX is not correct
tfm
I was looking for a complex multiplication, and found in the Quartus  in IP Catalog, Library/Basic Functions/Arithmetric the ALT_MULT_COMPLEX.
I used it with a enable,  let it produce a VHD file..    during compile if showed errors,
there where END IF's missing.
And looking further...   there are only 3 mulltiplies used in the code..
But of course a full complex multiplication need 4 multiplies.
So  the ALT_MULT_COMPLEX can not be used..
Do I need to pick an other IP ?
Theo Mulder
FvM
Valued Contributor III
Quartus version, target device, port widths and other non-default instantiation parameters?
tfm
Hi FvM,
Thanks for your reply..,
I already build my own complex multiplication, so i'm fine.
But to show the problem.., i attached the *.vhd file that was generated by the ALT_MULT_COMPLEX -IP.
at least one problem is:    the IF (ena = '1') THEN    do not have a closing END IF.
I used Quartus Prime Lite 22.1std.    And used a Cyclone V
Kind Regards,
Theo Mulder
FvM
Hi Theo,
I can confirm that the generated VHDL code doesn't compile due to syntax errors, the Verilog code is however syntactically correct.
Regarding usage of 3 multipliers, I'm not sure, but I guess it may be an alternative algorithm to calculate complex multiply. I didnt check the results. Here's the RTL schematic, if anyone knows about the algorithm.
Frank
FvM
additional info, I stepped back to Quartus V13.1, the MegawizardManager generates generates functional VHDL code here. RTL structure is the same.
Frank
Ash_R_Intel
Thanks for pointing the defect. I have raised this concern to the engineering team.
Ash_R_Intel
The issue has been acknowledged by the engineering team and will be fixed in future version of Quartus software. There will be a Knowledge Article published for the issue, so that all users are made aware of. Meanwhile, we request you to continue using the Verilog model of the IP as a workaround.
As there are no further queries on this topic, I am closing the case.
