17256 Discussions
ALTDDIO_IN pipeline delay differs from documentation
I'm using MegaWizard on Quartus II 9.0 to generate a DDR input buffer, and the hardware being synthesized doesn't match the documentation. The documentation (http://www.altera.com/literature/ug/ug_altddio.pdf and http://www.altera.com/literature/hb/cyc/cyc_c51010.pdf) shows the same pipeline delay for both ddr_out_h and ddr_out_l. See the first attached image (Fig 10-1).
The logic actually produced is shown in the second attached image (RTL viewer screenshot). This delays ddr_out_l by one clock cycle relative to ddr_out_h. I've checked and invert clock input is not selected in MegaWizard. I can easily add a register to ddr_out_h to match the delay, but if Altera fixes this discrepancy, it could break the design. Is the documentation correct, or the implementation? Has this bug been fixed in a later version of Quartus? Figure 10–4 in http://www.altera.com/literature/hb/cyc/cyc_c51010.pdf also doesn't match the logic in Figure 10-1, data_in_h and data_in_l are swapped.
David
The altddio user guide shows a circuit corresponding to the second (RTL) schematic in all versions I'm aware of (Figure 1-1 in V4.1 - V10.0). The Cyclone (I) Handbook circuit is actually different. Beginning with Cyclone II, the documentations seems to be consistent in this regard.
Is this also relevant to Cyclone IV devices? Other than this document I can't seem to find any specific Cyclone documentation that shows this, and Figure 3-1 seems to be specific to Apex II and Stratix series. If Figure 3-1 is correct, is the Cyclone handbook actually wrong, or not relevant to Cyclone II and above?
I'm also somewhat confused by the invert_input_clocks parameter of the ALTDDIO_IN megafunction. Does this simply invert the input clock right at the front end and therefore the dataout_h and dataout_l outputs then become synchronous to the falling edge?
Edit: More specifically, does dataout_h and dataout_l relate to the actual input clock edge rather than the inverted clock edge?
It would be really useful to have a full diagram similar to Figure 3-1 for Cyclone devices showing this.
Mark.
