I am using Quartus II 8.0 for programming a Cyclone III device. I have a 2 LVS clocks (fclk and lclk) and a channel (12 bit) LVDS input that I wish to deserialize. I use 2 channels and factor 6. In SOPC I create a ALTLVDS component ... In SOPC: Tools -> IP MegaStore... / Create a new custom megafunction variation / Cyclone III device,VHDL, ALTLVDS: LVDS_RECEIVER, 2 channels; deserialization factor = 6; use external PLL = ON; enable bitslip control = OFF; generate netlist = OFF; and the all options from last page = ON; and finish Later, in SOPC: Create new component -> in hdl menu, I load only the .vhdl file created in signals menu: rx_inclock = interface clock_sink (Clock Input); signal type = clk; rx_in = interface avalon_slave0; signal type = writebyteenable; rx_out = interface avalon_slave0; signal type = readdata; in interfaces menu: All default and associated clock = clock_sink and finish... My problem is: I add the ALTLVDS component in my SOPC project, but nothing happens in the main project in quartus ( after to compile ), in pin planner any pin from ALTLVDS componet appears (rx_in, rx_out...) and when I try to write some thing about the component in the main file (myproject.v) , the quartus doesn't recognize it... Please, help me....Link Copied
up
somebody can help me ?
