17257 Discussions
ALTPF_divide tool from Quartus
hi,
i am trying to use the MegaWizard tool for floating point division from Quartus, but when i run the test bench for the design i keep getting this error message
Fatal error in Process MEMORY at C:/altera/12.0/modelsim_ase/win32aloem/../altera/vhdl/src/altera_mf/altera_mf.vhd line 39809
# HDL call sequence:
# Stopped at C:/altera/12.0/modelsim_ase/win32aloem/../altera/vhdl/src/altera_mf/altera_mf.vhd 39809 Subprogram read_my_memory
# called from C:/altera/12.0/modelsim_ase/win32aloem/../altera/vhdl/src/altera_mf/altera_mf.vhd 41612 Process MEMORY
can anyone help me with this please?
If you expect help, you should post your code.
the code from megaWizard is very long so i uploaded it in the attachment
and here is the test bench i am using
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
library work;
use work.comppack.all;
use work.fpupack.all;
use work.txt_util.all;
use work.fixed_pkg.all;
use work.float_pkg.all;
use work.math_utility_pkg.all;
ENTITY mega_divide_tb IS
END ;
ARCHITECTURE mega_divide_tb_arch OF mega_divide_tb IS
SIGNAL datab : std_logic_vector (31 downto 0) ;
SIGNAL clock : STD_LOGIC ;
SIGNAL result : std_logic_vector (31 downto 0) ;
SIGNAL dataa : std_logic_vector (31 downto 0) ;
signal data_areal, data_breal: real;
COMPONENT mega_divide
PORT (
datab : in std_logic_vector (31 downto 0) ;
clock : in STD_LOGIC ;
result : out std_logic_vector (31 downto 0) ;
dataa : in std_logic_vector (31 downto 0) );
END COMPONENT ;
BEGIN
DUT : mega_divide
PORT MAP (
datab => datab ,
clock => clock ,
result => result ,
dataa => dataa ) ;
clock <= not(clock) after 5 ns;
verify : process
begin
data_areal<=1.0;
data_breal<= 1.0;
wait until (clock' event and clock= '1' );
datab<= to_std_logic_vector(to_float32(to_float(data_breal)));
dataa<= to_std_logic_vector(to_float32(to_float(data_areal)));
end process verify;
END ;
