16674 Discussions
AOCL Diagnostic problem: cannot find the upstream slot
Hello forum!
I have a problem with using DE5_NET board. Afted installation Quartus, AOCL SDK, BSP and setting Env variables i try diagnose board.
"aocl diagnose: Running diagnostic from C:\altera\14.0\hld\board\terasic\de5net/w
indows64/libexec
Verified that the kernel mode driver is installed on the host machine.
Using board package from vendor: Terasic Technologies
Querying information for all supported devices that are installed on the host ma
chine ...
MMD FATAL: acl_pcie_config.cpp:57: cannot find the upstream slot.
Assertion failed: 0, file acl_pcie_config.cpp, line 57
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
aocl diagnose: failed."
Driver set up correct. When i try program or flash board i get screen of death...
My OS - winows server 2012 R2.
--- Quote Start ---
Hello forum!
indows64/libexec
chine ...
--- Quote End ---
Hi, I have encountered the same issue. Did you resolved it? Can you give me some advices? Thanks
