ASMI IP Simulation
Hi I am trying to simulate the ASMI IP with Modelsim-Altera. I am a complete n00b and the instructions to simulate IP Cores are not very clear to me.
I can compile the design and make it work on the FPGA. But when I try it on Modelsim the IP does nothing.
I have included the .qip and .sip files. My flow to the simulation works as it follows:
  1. I click on Analysis and Synthesis.
  2. I go to Tools>Run Simulation Tools>RTL Simulation
  3. When Modelsim pops up I type on the console : vsim work.topfilename
  4. I create stimulus (manually, as there are not many signals).
That's all
THANK YOU!!
Hi there,
I have exactly the same issue. Just wondering if you was able to figure this out. Also, you mentioned that you was able to make it work in hardware, I had no luck in that either. Do you have a simple test project to share? I really to like to get it fixed.
Yev
