About Loop Unrolling
Hi everyone,
I am wondering if setting a unroll factor that is not multiple of loop count is OK in Altera OpenCL?
For example:# pragma unroll 10
for( int i = 0; i < n; i++){
Here n is either a number not divisible by 10 (ex: 128) or not known at compilation time (ex: a variable passed in from host). I know this can be done on CPU or GPU but I am wondering if this will generate incorrect result or cause performance issues on FPGA.
Thanks!
No, this will work. Depending on whether the iterations are independent or not, you may get performance increase because essentially FPGA hardware of the loop will be replicated 10 times.
Thank you for the reply!
So basically during the last unrolled iteration, only the reminder (in my example 128%10 = 8) number of the FPGA datapath will be used and the rest (again in my example 10 - 8 = 2) of the datapath will be bypassed right?
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Yes, this is correct.
--- Quote Start ---
--- Quote End ---
Thank you!
