17251 Discussions
Accessing SDRAM memory on Terasic DE0-Nano board.
I want to use SDRAM memory located on DE0-Nano board using Verilog (without using Nios).
I use http://www.altera.com/support/examples/nios2/exm-avalon-mm.html
System placed in the QSYS:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8357
sdram_write not currently used.
Code:
//======================================================= module SRAM( CLOCK_50, LED, DRAM_ADDR, DRAM_BA, DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_DQ, DRAM_DQM, DRAM_RAS_N, DRAM_WE_N //Memory pin ); //////////// CLOCK ////////// input CLOCK_50; //////////// LED ////////// output LED; //reg LED; //////////// SDRAM ////////// output DRAM_ADDR; output DRAM_BA; output DRAM_CAS_N; output DRAM_CKE; output DRAM_CLK; output DRAM_CS_N; inout DRAM_DQ; output DRAM_DQM; output DRAM_RAS_N; output DRAM_WE_N; //////////// AVALON MASTER TEMPLATE ////////// wire qsys_sdram_read_control_fixed_location; wire qsys_sdram_read_control_read_base; wire qsys_sdram_read_control_read_length; wire qsys_sdram_read_control_go; reg reg_qsys_sdram_read_control_fixed_location; reg reg_qsys_sdram_read_control_read_base; reg reg_qsys_sdram_read_control_read_length; reg reg_qsys_sdram_read_control_go; wire qsys_sdram_read_control_done; wire qsys_sdram_read_control_early_done; wire qsys_sdram_read_user_read_buffer; reg reg_qsys_sdram_read_user_read_buffer; wire qsys_sdram_read_user_buffer_output_data; wire qsys_sdram_read_user_data_available; reg gooff=0; reg rboff=0; reg init=1; qsys u0( .clk_clk(CLOCK_50), //clk.clk .reset_reset_n(1'b1), //reset.reset_n .sdram_clock_c0_clk(DRAM_CLK), //sdram_clock_c0.clk .sdram_clock_areset_conduit_export(1'b0), //sdram_clock_areset_conduit.export .sdram_wire_addr(DRAM_ADDR), //sdram_wire.addr .sdram_wire_ba(DRAM_BA), // .ba .sdram_wire_cas_n(DRAM_CAS_N), // .cas_n .sdram_wire_cke(DRAM_CKE), // .cke .sdram_wire_cs_n(DRAM_CS_N), // .cs_n .sdram_wire_dq(DRAM_DQ), // .dq .sdram_wire_dqm(DRAM_DQM), // .dqm .sdram_wire_ras_n(DRAM_RAS_N), // .ras_n .sdram_wire_we_n(DRAM_WE_N), // .we_n .sdram_read_control_fixed_location(qsys_sdram_read_control_fixed_location), .sdram_read_control_read_base(qsys_sdram_read_control_read_base), .sdram_read_control_read_length(qsys_sdram_read_control_read_length), .sdram_read_control_go(qsys_sdram_read_control_go), .sdram_read_control_done(qsys_sdram_read_control_done), .sdram_read_control_early_done(qsys_sdram_read_control_early_done), .sdram_read_user_read_buffer(qsys_sdram_read_user_read_buffer), .sdram_read_user_buffer_output_data(qsys_sdram_read_user_buffer_output_data), .sdram_read_user_data_available(qsys_sdram_read_user_data_available) ); assign qsys_sdram_read_control_fixed_location = reg_qsys_sdram_read_control_fixed_location; assign qsys_sdram_read_control_read_base = reg_qsys_sdram_read_control_read_base ; assign qsys_sdram_read_control_read_length = reg_qsys_sdram_read_control_read_length ; assign qsys_sdram_read_control_go = reg_qsys_sdram_read_control_go; assign qsys_sdram_read_user_read_buffer = reg_qsys_sdram_read_user_read_buffer; always @(posedge CLOCK_50) begin if (gooff) begin gooff <= 0; reg_qsys_sdram_read_control_go <= 0; end if (init) begin reg_qsys_sdram_read_control_fixed_location <= 0; reg_qsys_sdram_read_control_read_base <= 0; reg_qsys_sdram_read_control_read_length <= 8; reg_qsys_sdram_read_control_go <= 1; gooff <= 1; init <= 0; end end assign LED = qsys_sdram_read_user_buffer_output_data ; endmodule
Memory is not written so it should read garbage and display on the LEDs, but the LEDs do not light.
Why do you think the SDRAM should contain 'garbage'?
SDRAM is unlikely to contain anything from power up. Try writing a pattern to it before reading it.
Alex
I tried to write memory by DE0 Nano Control Panel, but it not help.
Is that the 'Control Panel' configuration that comes with the DE0 Nano?
If you use the control panel to write to the SDRAM and then reprogram the FPGA with your design, the SDRAM is not going to retain the values written using the control panel. During the FPGA reconfiguration the SDRAM refresh control will stop causing the SDRAM to 'forget' it's memory.
Alex
So why after reprogramming with my design DE0 Nano Control Panel reads previously saved values correctly?
Perhaps I should have said that, having reprogrammed your FPGA, you cannot guarantee to read back what you wrote to the FPGA...:)
So, we're back to your original question - why doesn't your code read the correct values. Is that right? I assume that, having used the control panel to write data, you reprogram with your code and hope to see LED activity?
Yes.&#8203;&#8203;&#8203;&#8203;&#8203;&#8203;&#8203;&#8203;&#8203;&#8203;&#8203;&#8203;
Your 'init' variable isn't doing what you want it to - i.e. being set to a '1' from 'power up' or reprogramming the FPGA. Declaring 'reg init=1' as you have will not result in that register taking that value. So, your conditional statement where you are testing init is never returning true and your code never runs.
You need to encode a way of setting init, either by means of a more traditional reset signal that triggers your always statement, or by means of a reset counter that starts up when the device does.
Assuming you have a button on your hardware I'd suggest the former might be easier. Extend your always statement to look for an edge generated by your new 'reset' button. If active, set 'init'. Once the button is released your conditional statement will return true, triggering the block to run.
Alex
'init' variable doing what I want it. I tested it.
Problem fixed. Need to wait two clock tacts before reading.
I also want to use SD-RAM to store and display a image on a VGA monitor, so if you could post the source files for reading form SD-card i would be really grateful.
Thanks in advance :)
I want to write SDRAM through my custom hardware IP. I am using the Master Templates for this. I am writing using custom hardware and reading using NIOS, but my bios doesn't read the correct value.
Below is my code for writing into SDRAM.
I want to write on the click of a button (coe_switch[3]). I have one more doubt, "myBuffer_control_write_write_base" should be the base address for SDRAM or offset or base+offest.
reg searchForSync;
always @(posedge csi_clk or negedge rsi_rst) begin
if(!rsi_rst) begin
click <= 0;
searchForSync <= 0;
end else begin
if(coe_switch[3] == 0) begin
searchForSync <= 1;
myBuffer_control_write_fixed_location <= 0;
myBuffer_control_write_write_base <= 32'h00000000;
myBuffer_control_write_write_length <= 8;
myBuffer_control_write_go <= 1;
myBuffer_user_write_buffer_input_data <= 1;
myBuffer_user_write_write_buffer <= 1;
end
if(searchForSync == 1) begin
myBuffer_control_write_go <= 0;
if(asi_stin_sop_reg[319] == 1) begin
end
end
end
end
Please let me know if I am doing something wrong.
Please suggest.
--- Quote Start ---
--- Quote End ---
Did you tried writing into SDRAM. I am trying but couldn't get the result.
Please check my post on the same thread.
Someone please suggest on the issue.
Post your problem in a new thread. Then more people will see it, not just those subscribed to this thread :).
Tip: please post more detail then you already have. The information you've posted isn't really enough. E.g. what does the code for your 'custom hardware IP' look like? Please wrap any code posted with code tags...
Alex
Dear Mikel7,
I would use a on Deo Nano board the SDRAM without using the Nios || processor, could you share your working code for SDRAM?
Thanks in advances,
Alexgiul
I'am not used this board for long time, but this should work:
//======================================================= module SRAM( CLOCK_50, LED, KEY, DRAM_ADDR, DRAM_BA, DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_DQ, DRAM_DQM, DRAM_RAS_N, DRAM_WE_N //Memory pin ); //////////// CLOCK ////////// input CLOCK_50; //////////// LED ////////// output LED; reg LED; //////////// KEY ////////// input KEY; //////////// SDRAM ////////// output DRAM_ADDR; output DRAM_BA; output DRAM_CAS_N; output DRAM_CKE; output DRAM_CLK; output DRAM_CS_N; inout DRAM_DQ; output DRAM_DQM; output DRAM_RAS_N; output DRAM_WE_N; //////////// AVALON CONNECTOR ////////// wire qsys_sdram_read_control_fixed_location; wire qsys_sdram_read_control_read_base; wire qsys_sdram_read_control_read_length; wire qsys_sdram_read_control_go; reg reg_qsys_sdram_read_control_fixed_location; reg reg_qsys_sdram_read_control_read_base; reg reg_qsys_sdram_read_control_read_length; reg reg_qsys_sdram_read_control_go; wire qsys_sdram_read_control_done; wire qsys_sdram_read_control_early_done; wire qsys_sdram_read_user_read_buffer; reg reg_qsys_sdram_read_user_read_buffer; wire qsys_sdram_read_user_buffer_output_data; wire qsys_sdram_read_user_data_available; reg gooff=0; integer start=3; qsys u0( .clk_clk(CLOCK_50), //clk.clk .reset_reset_n(1'b1), //reset.reset_n .sdram_clock_c0_clk(DRAM_CLK), //sdram_clock_c0.clk .sdram_clock_areset_conduit_export(1'b0), //sdram_clock_areset_conduit.export .sdram_wire_addr(DRAM_ADDR), //sdram_wire.addr .sdram_wire_ba(DRAM_BA), // .ba .sdram_wire_cas_n(DRAM_CAS_N), // .cas_n .sdram_wire_cke(DRAM_CKE), // .cke .sdram_wire_cs_n(DRAM_CS_N), // .cs_n .sdram_wire_dq(DRAM_DQ), // .dq .sdram_wire_dqm(DRAM_DQM), // .dqm .sdram_wire_ras_n(DRAM_RAS_N), // .ras_n .sdram_wire_we_n(DRAM_WE_N), // .we_n .sdram_read_control_fixed_location(qsys_sdram_read_control_fixed_location), .sdram_read_control_read_base(qsys_sdram_read_control_read_base), .sdram_read_control_read_length(qsys_sdram_read_control_read_length), .sdram_read_control_go(qsys_sdram_read_control_go), .sdram_read_control_done(qsys_sdram_read_control_done), .sdram_read_control_early_done(qsys_sdram_read_control_early_done), .sdram_read_user_read_buffer(qsys_sdram_read_user_read_buffer), .sdram_read_user_buffer_output_data(qsys_sdram_read_user_buffer_output_data), .sdram_read_user_data_available(qsys_sdram_read_user_data_available) ); assign qsys_sdram_read_control_fixed_location = reg_qsys_sdram_read_control_fixed_location; assign qsys_sdram_read_control_read_base = reg_qsys_sdram_read_control_read_base ; assign qsys_sdram_read_control_read_length = reg_qsys_sdram_read_control_read_length ; assign qsys_sdram_read_control_go = reg_qsys_sdram_read_control_go; assign qsys_sdram_read_user_read_buffer = reg_qsys_sdram_read_user_read_buffer; always @(posedge CLOCK_50) begin if (start==1) begin reg_qsys_sdram_read_control_fixed_location <= 0; reg_qsys_sdram_read_control_read_base <= 0; reg_qsys_sdram_read_control_read_length <= 2; reg_qsys_sdram_read_control_go <= 1; gooff <= 1; end if (gooff) begin gooff <= 0; reg_qsys_sdram_read_control_go <= 0; end if (start) start = start - 1; LED <= qsys_sdram_read_user_buffer_output_data ; end endmodule
