17268 Discussions
Add a new user logic using SOPC builder
I have been trying to add a user logic using SOPC builder, but I dont see that option in Quartus 8. Are their any other alternatives for the same which can be performed using Quartus 8. I did try to using add a new component, but then I get a lots of errors when I add a .vhd file. Is this the way to perform the task.
--- Quote Start ---
--- Quote End ---
No. You should not add a .vhd file to the custom component. You should only add signals in the custom component. This is only an interface. Later on, you should connect these interface signals to your logic in your HDL design.
could you please illustrate with an example.. guess its easier for me to understand the same with an example.
Abin
vizzie is mistaken. The Component Editor in SoPC builder can be used to create custom components based on HDL code or by simply exporting the bus. If you are getting errors when adding your .vhd file in the component wizard, you should read what those errors are and find and fix them in your HDL code.
I've created hundreds of HDL-based SoPC builder components. Trust me it works.
Jake
