17249 Discussions
Always block within always block
Hi guys,
Is it possible to use always@block within always block? The reason I want to do that is I try to construct multiple synchronised blocks using For loop, and you need to put loop statement in a always/initial block. My code is like:
always begin for(i=0;i<5;i=i+1)begin always@(posedge clk) begin ... end end end
I'm not sure whether this is synthesizable or not, please give some advice.
Cheers.
You'll want a generate statement
In this example: http://www.asic-world.com/verilog/verilog2k2.html
You can replace memory U with your always structure
Just be sure you don't generate multiple drivers for whatever reg you are writing
--- Quote Start ---
--- Quote End ---
Can this example be synthesized?
generate-for loops are synthesizable.
It does not make sense for an always block within an always block
yes, generate if is better choice
