17268 Discussions
An array of constants / parameters
I have several constants that I want to concatenate and place into an array (reg / parameter?). That array will be compared to another array of the exact same size.
reg setup_packet; reg byte0 = 8'h01; parameter getdevicedescriptor = {byte0 && byte1, word0, word1, byte2 && byte3 }; if (setup_packet == getdevicedescriptor) status <= rejoice; .....
I keep getting the following error and I just don't undertsand how to resolve the proper syntax. I don't really understand packed vs unpacked arrays. D;
--- Quote Start ---
Error (10673): SystemVerilog error at usb_protocol.v(46): assignments to unpacked arrays must be aggregate expressions
--- Quote End ---
You can read this paper (http://www.mentor.com/products/fv/resources/overview/using-strong-types-in-your-systemverilog-design-and-verification-c953bc93-075a-4b67-9e03-aab28f5bf696)to help understand the difference between packed an unpacked types.
Some tools have difficulty understanding the difference between a concatenation of bits which is a packed vector versus an unpacked array assignment, both of which use the {value1,value2} syntax. You can put a ' in front of the {} to ensure that it is recognized as an assignment pattern. See section 10.10 of the LRM
But then the array assignment '{} would expect 9 unpacked array elements each 16 bits wide.
Yup, the ' fixed it. Yes, the number of bytes/words I typed wasn't the correct number (9), but I was just being lazy. Thanks!
--- Quote Start ---
--- Quote End ---
Adding ' It doesnt fix my problem.
I use the following line
parameter reg [7:0] LCD_CMDS [0:23] = '{8'h3C, 8'h0C, 8'h01, 8'h02, 8'h48, 8'h65, 8'h6C, 8'h6C, 8'h6F, 8'h20, 8'h46, 8'h72, 8'h6F, 8'h6D, 8'h20, 8'h44, 8'h69, 8'h67, 8'h69, 8'h6C, 8'h65, 8'h6E, 8'h74, 8'h18};
and it returns=> Error (10170): Verilog HDL syntax error at PmodCLP.v(75) near text "'"; expecting an operand
Need help..:)
-Fahmy
Your file compiled fine in ModelSim. Make sure you are compiling your file as SystemVerilog (use .sv extension).
--- Quote Start ---
You file compiled fine in ModelSim. Make sure you are compiling your file as SystemVerilog.
--- Quote End ---
Thanks , it works with system verilog. All this while I was using .v.
-Fahmy
