Hi everyone, i have an enquiry regarding VHDL. let's say i have a 128 bits key which is split into 4 parts:
--divide the key into 4 parts
k0<=key(127 downto 96);
k1<=key(95 downto 64);
k2<=key(63 downto 32);
k3<=key(31 downto 0);
is it possible to do something like in c language in VHDL: k[0]=k0; k[1]=k1; k[2]=k2; k[3]=k3; where k[] is a 4 element array...i am aware that the bus width is uneven issue but is there anyway to implement this in VHDL? if not any ideas how i can implement this in VHDL? thanx in advance!
You can create an indexed type
type key_t is array (0 to 3) of std_logic_vector(31 downto 0); signal k : key_t; and then in your code, you can take advantage of loops too process(key) begin for i in 0 to 3 loop k(i) <= key(32*(i+1)-1 downto 32*i); end loop; end process; Cheers, Dave- Mark as New
hi dave, thank you so much for the informative reply! actually i'm trying to implement XTEA:http://en.wikipedia.org/wiki/xtea
The following is the VHDL code i'm working on:
Library IEEE;
USE IEEE.std_logic_1164.all;
use ieee.numeric_std.all;
entity XTEA is
Port (
clk:in std_logic;
input: in unsigned(63 downto 0);
key : in unsigned(127 downto 0);
Encoder_output,Decoder_output: out unsigned(63 downto 0)
end entity;
architecture rtl of XTEA is
signal k0,k1,k2,k3: unsigned(31 downto 0);
signal n:integer:=0;
signal key_array: unsigned (3 downto 0);
type key_t is array (0 to 3) of unsigned(31 downto 0);
signal k : key_t;
begin
process(clk,input)
variable z,z_up,z_mid,z_down,z_total,y,y_up,y_mid,y_down,y_total: unsigned (31 downto 0);
variable sum: unsigned (31 downto 0) := x"00000000";
variable delta: unsigned (31 downto 0) := x"9e3779b9";
variable test,test1,test2,test3 : unsigned (31 downto 0);
variable natvar,natvar1,natvar2,natvar3 : integer;
begin
k(3)<=key(127 downto 96);
k(2)<=key(95 downto 64);
k(1)<=key(63 downto 32);
k(0)<=key(31 downto 0);
if(rising_edge(clk)) then
if (n=0) then
--divide input into y and z
y:= input(63 downto 32);
z:= input (31 downto 0);
--sum:=x"00000000"; -- try take this out later
elsif (n=32) then
--for decode:delta is delta*2^5 for 32=(2^5) round
sum:=delta(26 downto 0)&"00000";
end if;
--encode
if (n <32) then
test:=sum and x"00000003";
test1:="00000000000" & sum(31 downto 11); --shift by 11 bits to the right
natvar:=to_integer(test);
natvar1:=to_integer(test1);
z_total:=(((z(27 downto 0)&"0000") XOR ("00000"&z(31 downto 5)))+z) XOR( sum + k( natvar downto natvar ) );
y:=y+z_total;
sum:=sum+delta;
y_total:=(((y(27 downto 0)&"0000") XOR ("00000"&y(31 downto 5)))+y) XOR (sum+ k(natvar1 downto natvar1 ) );
z:=z+y_total;
Encoder_output<=y&z;
--decode
elsif(n<64) then
if(n=32) then
sum:=delta*32;
end if;
test2:=sum and x"00000003";
test3:="00000000000" & sum(31 downto 11); --shift by 11 bits to the right
natvar2:=to_integer(test2);
natvar3:=to_integer(test3);
test1:=sum and x"00000003";
y_total:=(((y(27 downto 0)&"0000") XOR ("00000"&y(31 downto 5)))+y) XOR (sum+ k(natvar3 downto natvar3));
z:=z-y_total;
sum:=sum-delta;
z_total:=(((z(27 downto 0)&"0000") XOR ("00000"&z(31 downto 5)))+z) XOR(sum + k(natvar2 downto natvar2));
y:=y+z_total;
Decoder_output<=y&z;
end if;
n<=n+1; --counter
end if;
end process;
end rtl;
Using the method you suggested, i encountered some problems: Error (10327): VHDL error at XTEA.vhd(59): can't determine definition of operator ""+"" -- found 0 possible definitions The problem lines are bolded...apparently my array (named k(0 to 3)) has the type of key_t but other operations are done in unsigned type. i tried converting k() to unsigned using "unsigned(k())" but to no avail. is there anyway to go about this? Than a lot for the great help again! have a nice day ahead!:)
The cause of the error is different from what you assume. This expression can't work, because it results in a subarray rather than a single array element k( natvar downto natvar ). Do you mean k( natvar)?
In addition, an expression length error is involved with sum:=delta*32;- Mark as New
On another note - you're indexing into K (that has 4 elements) with a 32 bit integer. What happens when natvar2 or 3 are greater than 3?
Thank you FvM for pointing out my mistakes. yes i meant k(natvar)...also the delta*32
is not possible so i replaced it with delta(26 downto 5) & "00000"
. and the code works! thank you again for your help! on a side note, i am experiencing some weird simulation waveform where by after 64 counts, the cycle repeats itself again which is not suppose to happen (circled in red)
Apparently the integer counter is optimized to 0 to 63 range and overflows. If you want to stop operation after one pass, you should do explicitely.
