17268 Discussions
Arria 10 TX transceiver slew rate
dncmrc1
Can the Arria 10 TX transceiver slew rate be reconfigured on-the-fly or is this a synthesis-only parameter?
Marco
JonWay_C_Intel
On further analysis, i checked the register map
https://www.altera.com/content/dam/altera-www/global/en_US/others/literature/hb/arria-10/a10_registermap.xlsx
if link doesnt work, check this:
https://www.intel.com/content/dam/altera-www/global/en_US/others/literature/hb/arria-10/a10_registermap.xlsx
which there was slew rate RW register at 0x10c. You should be able to change at runtime and observe with oscilloscope
JonWay_C_Intel
No, you cannot change the slew rate at runtime.
JonWay_C_Intel
