17255 Discussions
Assigning individual bits
Hi all,
I'm a complete newbie in Verilog, so I have a question.
I have in my main Verilog file (irrelevant code stripped out):
//======================================================= // This code is generated by Terasic System Builder //======================================================= module Lab2( //////////// SEG7 ////////// HEX0, HEX1, HEX2, HEX3, HEX4, HEX5, HEX6, HEX7 ); //////////// SEG7 ////////// output HEX0; output HEX1; output HEX2; output HEX3; output HEX4; output HEX5; output HEX6; output HEX7; Default u0 ( .id7seg_display_export (???) ); endmodule
Now, Default.id7seg_display_export is declared as:
output wire id7seg_display_export // id7seg_display.export
My question is, how do I connect individual bits from id7seg_display_export to the different HEX outputs signals? I just can't figure it out because I don't know the syntax...
That's very simple. Some examples:
assign HEX0 = id7seg_display_export[6:0];
assign HEX1 = id7seg_display_export[13:7];
assign HEX2[0] = id7seg_display_export[3];
assign HEX2[4:1] = id7seg_display_export[12:9];
assign HEX2[6:5] = id7seg_display_export[20:19];
The last 3 above could even be companded into a single one:
assign HEX1[6:0] = { id7seg_display_export[20:19], id7seg_display_export[12:9], id7seg_display_export[3]};
Are you sure that works?
For doing
I get that id7seg_display_export is undefined. Slapping in uc, as in:
assign HEX2[0] = uc.id7seg_display_export[3];
gives another error, something like cannot resolve assign id7seg_display_export (dunno if this is right anyway).
BUT, I managed to get it working by using (yes, I changed the name):
.seg7_display_export ({HEX3, HEX2, HEX1, HEX0})
Sorry, You are right.
I didn't notice that id7seg_display_export is actually the name of the submodule port.
I treated it like a common signal
I mean, what I wrote should apply in this case, where the same name is defined for the top level signals
wire [27:0] id7seg_display_export;
Default u0 (
.id7seg_display_export(id7seg_display_export)
Oh, right, that's another way of doing it.
Thanks for the help!
