Hi all,
I started working with Altera OpenCL a few weeks ago and I am still trying to get familiar with the collection of tools provided with the Altera SDK for OpenCL. Right now, I am having trouble to get the AOCL profile information viewer up and running as any attempt to launch it results into the following error: "Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException". Any idea on how to get rid of this exception?:( The system I am currently using runs Windows 7 (64-bits) and has a Stratix V FPGA board connected via PCIe. Also, I am working with Altera SDK for OpenCL v14.0.2.209 and the application I used is the JPEG Decoder Design Example provided by Altera: http://www.altera.com/support/examples/opencl/jpeg-decoder.html Here is a description of steps I went through: - Compiled the jpeg_decoder.cl kernel to obtain the .aocx file including profiling instrumentation Command: "aoc --profile -v --board s5phq_d5 device/jpeg_decoder.cl -o bin/jpeg_decoder.aocx" - Imported the Visual Studio project to VS2013 and built it to obtain the jpeg_decoder.exe executable (copied to bin directory) - Ran the application to generate the profile.mon file Command: "jpeg_decoder.exe 1.jpeg 1.ppm" - Invoked the AOCL profile information viewer Command: "aocl report jpeg_decoder.aocx profile.mon" Attached is a screenshot of the actual error message. Thanks!:) DavidLink Copied
Thank you for the report. I will try to replicate the issue.
There were a couple of profiler bugs that were fixed in 14.1; this may be one of them. I recommend updating, if possible.- Mark as New
Hi Outku,
Thanks for the reply and for your advice. Actually, I have contacted Altera's support yesterday and they suggested the same: a clean install of Quartus 14.1, which I did. Unfortunately, tough the error message changes slightly, the problem seems to remain (c.f. screenshot attached). By the way, support member pointed out that environment variables needed to be set correctly, which I checked successfully (ALTERAOCLSDKROOT, QSYS_ROOTDIR and QUARTUS_ROOTDIR). David- Mark as New
--- Quote Start --- Hi Outku, Thanks for the reply and for your advice. Actually, I have contacted Altera's support yesterday and they suggested the same: a clean install of Quartus 14.1, which I did. Unfortunately, tough the error message changes slightly, the problem seems to remain (c.f. screenshot attached). By the way, support member pointed out that environment variables needed to be set correctly, which I checked successfully (ALTERAOCLSDKROOT, QSYS_ROOTDIR and QUARTUS_ROOTDIR). David --- Quote End --- did you try to rebuild .aocx and rerun the host to produce profile.mon with 14.1? Or, did you just do "aocl report" with the 14.1 using your 14.0 old files? I tried the jpeg_decoder here with 14.1 and the profiler works as expected.
--- Quote Start --- did you try to rebuild .aocx and rerun the host to produce profile.mon with 14.1? Or, did you just do "aocl report" with the 14.1 using your 14.0 old files? I tried the jpeg_decoder here with 14.1 and the profiler works as expected. --- Quote End --- Good thing that you mentioned it! Actually, I have not rebuilt the .aocx using 14.1. I only re-used the .aocx and profile.mon I originally obtained using 14.0. I will try that as soon as I can and keep you updated on the result. Thanks.
I tried to correct a typo on the original post I wrote in this thread but saving the changes I made completely deleted it! Sorry...
Here is what I wrote in my original post: --- Quote Start --- Hi all, I started working with Altera OpenCL a few weeks ago and I am still trying to get familiar with the collection of tools provided with the Altera SDK for OpenCL. Right now, I am having trouble to get the AOCL profile information viewer up and running as any attempt to launch it results into the following error: "Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException". Any idea on how to get rid of this exception? The system I am currently using runs Windows 7 (64-bits) and has a Stratix V FPGA board connected via PCIe. Also, I am working with Altera SDK for OpenCL v14.0.2.209 and the application I used is the JPEG Decoder Design Example provided by Altera: http://www.altera.com/support/examples/opencl/jpeg-decoder.html Here is a description of steps I went through: - Compiled the jpeg_decoder.cl kernel to obtain the .aocx file including profiling instrumentation Command: "aoc --profile -v --board s5phq_d5 device/jpeg_decoder.cl -o bin/jpeg_decoder.aocx" - Imported the Visual Studio project to VS2013 and built it to obtain the jpeg_decoder.exe executable (copied to bin directory) - Ran the application to generate the profile.mon file Command: "jpeg_decoder.exe 1.jpeg 1.ppm" - Invoked the AOCL profile information viewer Command: "aocl report jpeg_decoder.aocx profile.mon" Attached is a screenshot of the actual error message. Thanks! David --- Quote End ---
Topic Options
