17252 Discussions
Avalon Streaming clock crosser does not generate HDL without errors. It cannot find it's own .v file
tejaswiniitagi
I want to generate an Avalon streaming clock crosser and when I clock on generate there is an error that says the altera file is not found. Is this a tool error that the file does not exist?
Error: st_clock_crosser_0: /nfs/site/disks/crt_tools_048/altera/quartus_prime_pro/22.1.0.174/ip/altera/avalon_st/altera_avalon_st_clock_crosser/altera_avalon_st_clock_crosser.v (No such file or directory)
IntelSupport
Community Manager
Yean in PD, try to generate the HDL and the issue came out as described?
Can we have a quick call?
IntelSupport
Community Manager
As per call, I can reproduce the issue, and indeed this is a tool bug.
Ill file to to developer for a fix and you may use AXI bridge as discussed.
tejaswiniitagi
Actually I need clock converter from one frequency to another. The AXI bridge will not convert the clock. So I will need the clock crosser itself.
IntelSupport
Community Manager
This is legit bug during generation of hdl for this IP. I am reporting to to developer for fix.
tejaswiniitagi
Can you please let me know when the fix will be done? I need to use the streaming clock crosser.
IntelSupport
Community Manager
Developer is working on that , the suggestion is to use use avalon streaming handshake clock crosser
IntelSupport
Community Manager
The developer mentioned that this IP will be discontinued and you may use the suggested IP and WA.
Let me know if there is any concern on this.
IntelSupport
Community Manager
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
tejaswiniitagi
/nfs/site/disks/crt_tools_048/altera/quartus_prime_pro/22.1.0.174/quartus/eda/sim_lib/altera_mf.v
This file has compilation errors when used to compile for handshake clock crosser.
Can you please check if it compiles?
I'm getting the following error message
is not a hexadecimal value
