BFM AXI4lite
Hi!
When I compile BFM with Modelsim, there is a problem: Cannt find mgc_axi4_pkg.
Someone knows what can I do?
thx
You may refer to the example provided in
\altera\15.0\ip\altera\mentor_vip_ae\axi4lite\examples\ex1_back_to_back_vhd
I tried but it has the same problem. where can I find mgc_axi4_pkg
The mgc_axi4_pkg package is defined in mgc_common_axi4.sv (located at \altera\15.0\ip\altera\mentor_vip_ae\axi4\bfm directory). I would expect modelsim dumps "# ** Error: (vlog-7) Failed to open design unit file "../../../../axi4/bfm/mgc_common_axi4.sv" in read mode." if can' find such file.
You can try simulation mixed language when you do generation Qsys.
