17258 Discussions
Backspace character in System Console
I am testing some memory using System Console and I would like to make a simple progress bar which will show current progress. For that I would need a backspace character.
The Tcl interpreter from Centos 7 works as expected:
$ tclsh % puts $tcl_version 8.5 % puts "abc\bd" abd
But System Console gives this:
% puts $tcl_version 8.5 % puts "abc\bd" abcd
Is there any way I can delete current characters or maybe whole line in System Console?
Probably not. System Console is a very crippled console interface which I believe is based on Jacl (a Java TCL interpreter).
You might be better off looking at the Dashboard widgets and see if you can use a progress indicator there.
Cheers,
Dave
The solution is so simple that I am almost ashamed to post it. You don't have to delete anything if you dont print anything, so for a very simple progress bar it is enough to print a character on the right iterations.
Here is the code:
set BAR_LEN 50 # ############################################################################## # Puts top line proc put_top_line { } { global BAR_LEN puts -nonewline "|" for {set i 0} {$i < $BAR_LEN} {incr i} { puts -nonewline "-" } puts -nonewline "|\n" } # ############################################################################## # Puts# to fill the progress bar, should be called every loop iteration proc put_filler {cur max} { global BAR_LEN if { } { puts -nonewline "|" } elseif { } { puts -nonewline "|\n" } else { set curValue set nextValue if { } { puts -nonewline "#" } } } # ############################################################################## # Test put_top_line for {set i 0} { $i < 1000 } { incr i } { put_filler $i 999 after 10 }
