17255 Discussions
Bad code, but no error, will settle for warning :)
This code compiles(!).
always @ (posedge clock ) begin
state <= NextState;
state <= state;
state <= 0;
end
Using the SignalTap it appears that state gets set to 0. Apparently its valid code. Is there a way to at least get a warning out of this?
Thank you,
Steve
Why would you want a warning for perfectly valid code?
The user has to take some responsibility!
You may want to invest in a linting tool.
Indeed. Thanks so much
I actually use that method when I want a default value on a signal. That way 'a' will always have a value even if I don't assign it in the if statement.
always@(posedge clk)
begin
a <= 1'b0;
if(something)
begin
a <= 1'b1;
end
else if(something else)
begin
<something that doesn't touch a>
end
end
--- Quote Start ---
end
--- Quote End ---
This seems like a good practice. Now I see the value of such a method.
Thank you,
Steve
