Hi everyone,
can somebody explain me the values of bandwidth efficiency in the Altera Dynamic Profiler for OpenCL? Like in the screens attached to this post, in a kernel that I'm working on I get an efficiency value of 1.5%. When, in reality, I read at ~6510 MB/s out of 12800 MB/s from each bank. What am I missing here? :confused: Thanks, Nicola.Link Copied
It depends on the memory access unit size you use and the number of memory load/store instructions.
ah thanks wzk6_3_8!
I also found this: --- Quote Start --- The overall efficiency is the percentage of total bytes, acquired from the global memory system, that the kernel program uses. --- Quote End --- So I guess I'm getting low efficiency values because the .aocx file contains multiple lead/store instructions. Thanks, Nicola.- Mark as New
--- Quote Start --- ah thanks wzk6_3_8! I also found this: So I guess I'm getting low efficiency values because the .aocx file contains multiple lead/store instructions. Thanks, Nicola. --- Quote End --- Yes, the load/store instructions share the memory bandwidth.
