17255 Discussions
Beginner question about making a beep sound
I am so sorry to ask such a simple question, which i have been thinking for whole night already.
Here are the codes
module music(clk, speaker);
input clk;
output speaker;
reg [15:0] counter;
always @(posedge clk) counter <= counter+1;
assign speaker = counter[15];
endmodule
[/B][/B][/B][/B][/B][/B][/B][/B]My question is :
1. Anyone can explain the logic to me. I very a beginner.
2. " always@(posedge clk) counter <= counter+1;" means it has positive clock only when counter is smaller than counter +1, but what is counter physically in this case??
3. Assign speaker to one of the value of counter is understandable, however, why then the speak will make a sound of frequency 381Hz if the input clock is set to be 25MHz, i know it's from 25MHz/65536= 381Hz, but i just dont understand why. how come? what is happening here?
Anyone can explain this? i will appreciate that. Thank you so much:oops:
<= is the assignment function. so it increments the counter by 1 on every positive edge of the clock.
The speed is because thats the toggling frequency of bit 15.
i have been to asked to use altera for programming in verilog HDL
i want to know the basics of how to consruct schematic and execute please anyone help
regards
h g rashmi
--- Quote Start ---
regards
h g rashmi
--- Quote End ---
I suggest you start your own thread, rather than hijacking other threads.
