17256 Discussions
Bitstream generation for Stratix-V chips
I'm using Quartus 11.0SP1 to build a Stratix-V design. I'm getting the following message during Assembler stage:
info: compilation report contains advance information. specifications for device 5sgxea7k2f40c2es are subject to change. contact altera for information on availability. no programming file will be generated.
I tried other S-V chips and tool options - still, Quartus refuses to generate the bitstream.
Also, a couple of example designs were built with exactly the same tool version.
I opened a service request with Altera, but it's kind of slow.
Any help is appreciated.
Evgeni
you should upgrade to 11.1, 5SGXEA7ES has full support
That worked.
