17254 Discussions
Block Editor - changing the page or sheet size
Now that I have the Block Editor running (thank you), how do I change the default sheet size to something smaller, like B (11 x 17)? The default size is huge, making scaled-down B-size prints too small to read.
ak
Hie analogkid,
you can to File > Page Setup and select your page size
then go to View > Show Page Breaks and you will see a blue border which shows you the edge of your sheet.
you can verify this using the Print Preview =)
hope this helps and good luck!
