16976 Discussions
Bug report -- Platform Designer generate .regmap with all peripherals' Address set 0x00000000
tommmy
the baseAddress in .regmap file generated by *.sopcinfo using Platform designer is not right.
it always has these content in every peripheral node:
<peripheral>
<baseAddress>0x00000000</baseAddress>
</peripheral>
the baseAddress should be set use the real base address in sopcinfo rather than just copy from the .svd file specified by SVD_PATH in  *_hw.tcl.
.regmap can be very usefull when debugging nios2, if the baseAddress set correctly,.
ShengN_Intel
