17255 Discussions
Bugs in Process Panel of Quartus II 9.1
It seems that Quartus II Process panel has some difficulty updating the status of process. For example, after running "Analysis and elaborate", I run partition merge, after partition merge complete, the whole Analysis & Synthesis becomes outdated again.
Very confusing and inefficient 'cos it will re-run the updated process which is unnecessary.
Jeff
i've noticed this too, if you use the Processing > Start menu i don't think this relies on Smart Compilation.
When i run RTL viewer, the processes also becomes outdated!
yes, i've seen that too
