17261 Discussions
Byte Blaster with Addressable Scan Port
A systemrack is filled with 10 boards , all equiped with a LVT8996 Addressable Scan Port (TI).
With the "normal" Boundary Scan tools I can detect the address and open the ASP.
Is it possible to detect/open an Addressable Scan Port (LVT8996 TI) with the USB Byte Blaster?
Thanks Hans
Hello Hans,
maybe with the JAM Player you can send a sequence to open a port. Once I programmed a DSP-Flash with the JAM player, but the DSP-Flash tool generated a STAPL file I could run with JAM player. I just had to handwire the JTAG signals.
Kind regards Ralf
