17265 Discussions
Calculating parameter value with self-written function
I'm currently working on a project where I need to calculate the length of a specific vector with the help of a (constant) function.
I use QuartusII (13sp1) and Systemverilog.
The module parameters/ports look like this:
module LZD# ( parameter INPUT_WIDTH = 54, parameter OUTPUT_WIDTH = 6 ) ( input logic input_string, output logic count );
Inside this module I have two localparams:
localparam INTERN_WIDTH = 2**OUTPUT_WIDTH; localparam POS_WIDTH = get_array_length;
Where get_array_length is a function, that returns a value based on some calculation only with the other parameters.
function int get_array_length(int OUT = OUTPUT_WIDTH, int N = INTERN_WIDTH); int result = 0,k; for (k=0; k<OUT; k++) begin : LOOP result = result + (OUT-k)*N/(2**(OUT-k)); end return result; endfunction
From what I have read about parameters, they can be assigned using functions if these are constant at compile time. Which my function should be, as it only uses parameters as inputs.
When I compile this module on its own, I don't get any errors and synthesis also looks as intended. But this module is just a submodule. When I try to compile the top-module, I always get the following error:
Error (10192): Verilog HDL Defparam Statement error at LZD.sv(24): value for parameter "POS_WIDTH" must be constant expression
(Line 24 is "localparam POS_WIDTH = get_array_length"; )
In the top-module, LZD is instantiated via
LZD# ( .INPUT_WIDTH(2*MANTISSA_WIDTH+1), .OUTPUT_WIDTH(COUNT_WIDTH+1) ) LZD_Instance( .input_string(mantissa_negate), .count(leading_zero_count), .no_one(no_one) );
and MANTISSA_WIDTH and COUNT_WIDTH are parameters inside the top-module.
parameter MANTISSA_WIDTH = 27; parameter COUNT_WIDTH = 5;
Is this a bug, is QuartusII not able to get the parameter values out of the hierarchy or is there anything else wrong in my code? I tried to find anything related to such things, but all I could find were papers or posts that mention that it's possible to calculate a parameter with a constant function. (Which seems to work in case the module is not further instantiated)
Thanks for any help!
