17257 Discussions
Can generate POF file with OpenCore eval license
Hi. I try use in my design the SDI II core. I dont have license for it. I want compile my project and test SDI with JTAG connection. I use Arria 10 device and Quartus Prime Pro 17.1. I sucessed fit the design in the device, but when I try generate POF file I get warning:
Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
Unlicensed IP: "SDI II Video Interface (6AF7 0111)"
I enable Intel FPGA IP Evaluation Mode, but it doesnt help.
Why I cant geneate a fimware?
--- Quote Start ---
I enable Intel FPGA IP Evaluation Mode, but it doesn't help.
--- Quote End ---
By default, it is enabled.
I am able to replicate the issue faced by you with Quartus Prime Pro 17.1. & I got same warning & because of this, I couldn`t get the .sof file.
But I could able to generate the .pof file with Quartus Prime standard 17.1.
It seems to be a bug.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
