Guys,
Why can't I write into EPCS16 on Quartus II 12 Web edition ? thanksLink Copied
There are many ways to "write into EPCS", e.g. AS programming, JTAG indirect programming, NIOS programmer, through altasm_parallel.
Which problem are you describing?- Mark as New
--- Quote Start --- There are many ways to "write into EPCS", e.g. AS programming, JTAG indirect programming, NIOS programmer, through altasm_parallel. Which problem are you describing? --- Quote End --- I got it, I used JTAG Indirect programming, Thanks
